File Geodatabse single layer downloads not working on ArcGIS Hub Open Data Site
1941
12
03-21-2019 03:41 PM
TaupoDistrict_Council
I am having problems downloading ArcGIS Online hosted feature layers as File Geodatabase from the open data site. the problem only occurs when attempting to download a single layer from within a hosted feature layer. The download status gets stuck on 'Gathering Data'. I have indexed the item multiple times. I am only testing with small datasets. Is this a known issue? Any ideas?
DanielFenton1
Occasional Contributor III
Currently we are unable to provide new file geodatabase downloads. The feature should be restored by tomorrow. I will update you here when there is news.
Daniel Fenton
CortDaniel1
New Contributor III
Thanks for the notification.
Cort
DanielFenton1
Hi Cort, this issue has now been resolved. Thank you for your patience.
Daniel Fenton
DanielFenton1
This issue has now been resolved.
Thank you for your patience,
Daniel Fenton
Hi Daniel, thanks for the update. Unfortunately, I am now receiving a different error. Is this related?
Ella (Taupo District Council)
DanielFenton1
No that is unlikely to be related. Can you please provide a link to the dataset you tried to download?
Thanks Daniel. Here is an example: https://data-taupo.opendata.arcgis.com/datasets/18a631f055604d5592a97ac088af37cb_0, it is a Hosted Feature Layer in ArcGIS Online.
DanielFenton1
I can confirm that this is an unrelated issue. Nevertheless we are looking into it now.
DanielFenton1
This issue is now resolved. We will do some cleanup work shortly to fix any other datasets affected by the same issue. Thank you for bringing this to our attention and sorry for the inconvenience.
Daniel Fenton
