Hello I am using Field Maps version 22.4.2 Our team takes before and after pictures as part of our use of Field Maps to document work completed in the field. We have several of our Technicians editing their own projects all on the same same map and layers. Ideally we would like to configure the sync function to upload geometry and photo updates (captured from within Field Maps) from each tech's device to the server without downloading photos from every other Tech's projects (since it needlessly consumes so much of their phone's data storage). Can we configure Field Maps' sync function like this?
As a work around, our team leader has created a feature layer just for markers of locations where photos were taken, and the markers are used to navigate back to to take the after picture. These photos are captured and stored in a phone or iPad photo album and exported manually which is more cumbersome. The sync function still update across all team members' devices but since it is just a marker and some text syncing across all devices, it consumes much less storage than actual photos. But still not ideal. Does anyone have a suggestion for smoother way?
If we can't configure the sync function as described above, can we configure Field Maps to automatically leave a marker on the map where a photo was captured to navigate back to? I'm hoping there some script that can be added somewhere, or setting I am not aware of?
Thanks in advance for your help.
