Arcade Calculations Offline - Sync - Do the calculations recalculate when syncing?
616
04-07-2023 05:29 PM
kmsmikrud
In a few Field Maps forms we have added arcade calculations and work offline. For one of the calculations, it was querying the layers for a max value (which I ended up changing the logic since offline this value is different than online). Anyway what a few users experienced is the feature/form offline would populate and they would submit their edits. The points show on the map, but then when they would sync the offline edits the one field with this 'maximum' calculation changed which in our case was the sample number/label on the map so it was an obvious change. This didn't make sense except if the form recalculates when syncing?
Thanks for the info!,
Kathy
