Search Webmaps Via Tags
452
12-05-2022 07:00 AM
Status: Open
Keith_Darby
I would like the ability to filter the maps that are in the web version of ArcGIS Fieldmaps through tags. For example, if you have various webmaps that have tags as utilities, you should be able to search by that method. Many agencies may probably have multiple maps that use tags and can be useful for filtering active or inactive maps.
Tags (1)
1 Comment
ChristopherCounsell
Tags are used to help drive the search functions across ArcGIS. If you add a tag to the web map, it will be used by the ArcGIS Field Maps web app search bar to filter results.
You can also use search expressions to remove maps with tags e.g. searching -inactive will remove all maps from the Field Maps web app with the inactive tag.
Suggest updating the Idea to have the Field Maps web app have the same preset filters that ArcGIS Online content search does, allowing users to use the buttons to filter content. Not just for tags but categories, status, date created etc.
