We really miss the option to be able to import sideloaded Mobile Map Packages into another offline ArcGIS Field Maps data collector app. It seems redundant and not very efficient that we have to upload all our ArcGIS Pro data and maps to AGOL to include them as feature services in the web map, and then download them again to the app as offline area packages.
In our case, it would be more efficient if we only needed to download the Field Map collector app which only has a download size of 10 MB with a simple vector basemap. The rest of the maps could then be pre-sideloaded as MMPK onto the device instead of having the whole package as an offline area package which has a download size of around 1,5 GB which is not optimal.
When we now have the option to create Mobile Map Package in ArcGIS Pro and sideload them directly to the mobile device, then there should be a map setting to be able to import the MMPK and its maps when both the spatial references system and area extent covers the same. Currently it is only Vector Tile Packages which are supported in the Field Maps offline settings ("Use a tile package for the offline basemap").
