Map filtering trigger does not work when selecting date values in a chart
295
09-11-2024 04:28 PM
LRoberts_RDM
I have an experience builder app that has a fire hydrant map and corresponding charts of dates tested and dates exercised. When I set up a trigger on the chart to filter the map when a value is selected, it does not filter the map.
I have another chart in my experience builder app that uses a numeric field for year values, and it works great for filtering. Is there a reason why date values do not work for selecting and filtering, or is there a different method I should be using?
Ke_Xu
by Esri Contributor
Hi LRoberts_RDM,
Thanks for bringing up this. I could reproduce this issue. We will look into it and keep update with you.
Ke
Ke_Xu
by Esri Contributor
Hi @LRoberts_RDM ,
Could you add a text or numeric field, calculate the year, and then filter the map using that field?
Ke
