Legend/Layer in Map widget open by default
1274
05-16-2022 03:48 AM
Marokapara
In Experience Builder's Map Widget, is it possible to set the legend and layer functionalities to be open by default so users who are unfamiliar with using maps will know right away where the legend/layer area is?
JillianStanford
Occasional Contributor III
Good morning,
I don't thing you can configure the "tools" that are part of the Map widget to open by default but you could add a new Widget Controller widget to the app, then add the Legend widget to it. You can then configure a widget to open on load.
Does that get you what you need?
Jill
JillianStanford
Good morning,
Jill
Marokapara
That's a good idea. Thanks.
