Inspect Images in OIC and delete Image from OIV in experience builder
538
03-28-2023 01:38 AM
jauhari_mani
How can we inspect through images and annotate the image of OIC and store it in the catalog and generate an issue from OIC widget itself.
Also is a way to view metadata of the image in OIC viewer and add/edit some columns in the OIC itself.
vickyduran_AerialSphere
The only way I believe you can edit the OIC data is by using Oriented Imagery Management Tools for ArcGIS Pro to create the OIC. In ArcGIS Pro you can see the Exposure points of each image in the OIC and add/edit fields/columns.
