How to use mailto link as URL
5081
6
08-21-2020 09:44 AM
Min-HungChou
I am using the Button widget and am trying to link the button to open up a new window to send an email. So far I have not been able to find success in this.
I set
Link to to Web Address
URL to mailto:example@organization.org
Open in tried all 3 options
Is there a correct format to do this, or it is simply not supported?
Thanks
Tags (1)
2 Solutions
DavidMartinez
Currently, the only way to add this is via the embed widget via code. For example, <a href="mailto:somebody@company.com ">Send email</a>. We have this logged as an issue for us to look at how we can improve this within Experience Builder.
    Thanks,   David
TonghuiMing
Starting from AGOL 10.3, you can configure mailto and some other URI schemes directly in the 'Set Link > URL' for widgets like Button, Image, etc. See details in:
https://doc.arcgis.com/en/experience-builder/latest/build-apps/add-widgets.htm#ESRI_SECTION1_0F7788F...
DavidMartinez
    Thanks,   David
ECH_HDR
Unfortunately, the "code" section of the embed widget does not connect to the selected feature or to the data as far as I can tell, which makes this of limited usefulness. We need to have a different "mailto" link for every feature in our feature class. Is a custom widget our only remaining option?
WilliamRockwell1
How is it 2024 and still not working?
TonghuiMing
Irishgeoff
https://veilmail.io is good if you want to hide your email address as a URL
Irishgeoff
