Full extent doesn't work properly
436
11-08-2023 06:59 AM
AliAwadBUK
New Contributor III
Hello,
I have an Experience Builder in which I embedded another Experience Builder containing a map with a header. The issue I'm facing is that when I click on "full extent" on the map, it doesn't open in full screen; instead, it only hides the header but remains in the same small window. How can I fix this?
the reason of using an experience builder for the map is we are going to add some widgets later on such as Filter and
Ali
TonghuiMing
Hi @AliAwadBUK
I remember there were a few full-screen-related issues fixed in the AGOL 2023 R01 release. That means if you're using Enterprise version 11.1 or older, you might encounter some issues.
AliAwadBUK
New Contributor III
Hi @TonghuiMing
I am using the AGOL for this Experience Builder, and I have another issue that I am unable to get out from the full extent (working if I embedded or added a map not another EB).
any ideas?
