Experience Builder Pie Chart Widget - Legend Scroll Bar
1040
10-10-2023 08:32 AM
Bobby_Lloyd
To get familiar with Experience Builder, I'm following along with this tutorial: https://learn.arcgis.com/en/projects/get-started-with-arcgis-experience-builder/
When adding the pie chart with a legend, the legend items do not all appear - a scroll bar is automatically included. There are only 3 legend items, so I thought surely there must be a way to make them all be visible without a scroll bar. However, after messing with the chart widget size and other settings, I cannot find a way to get all of these elements visible without a scroll bar. Has anyone else dealt with this issue and found a solution? Or perhaps am I missing a setting option somewhere?
JeffreyThompson2
MVP Regular Contributor
You can resize widgets by clicking on the widget (to select it as the active widget), then clicking and dragging the white bars.
GIS Developer
City of Arlington, Texas
ChenChen4
New Contributor III
Thanks for the suggestion. I tried resize but it does not seems to expand the space for the legend area:
SpencerCook
I had the exact same problem on the same tutorial. I managed to get rid of the scrollbar by changing the legend font away from Avenir Next, in Appearance -> Text Settings -> Legend Label. Maybe not the most elegant solution, but it seemed to work for me.
ChenChen4
New Contributor III
Probably this is the best solution so far.
JosephKinyon
New Contributor II
This was the only solution I could find also, the are no properties to manage the legend dimensions and using avenir at 14 pt meant auto, stretch, nor custom worked--always resulted in a scroll bar.
