Hello all,
I am really hoping there is a good solution to this.
I am having screen size / resolution issues with Map Image Layers that are associated with my experience. When the computer screen is in the 1920 X 1080 resolution everything works perfectly, but when I switch to 2560 X 1440 the Map Image Layer is completely broken.
This image is the screen resolution at 1920 X 1080:
As you can see this is working perfectly.
This image is the screen resolution at 2560 X 1440:
As you can see something is very wrong here.
Any help or insight with this issue is very appreciated.
EDIT: This issue is effecting only 2D maps.
