Change Flash Color of Query Widget Map Results from Yellow to Another Color
166
01-21-2025 03:14 AM
jantolihao
Hello, everyone!
I am trying to change the flash color from yellow to another color. I am using a query widget then the map should zoom and flash to selected record. Please see screenshot below.
I have already tried the following, but didn't work.
  • Tried changing the color of the Highlight Fill and Outline under Feature Selection Colors (Option Section) in the Map Widget
  • Tried adding Action in the Query Widget "Records Created - Show on Map" with Use Custom Symbols setting
Has anyone encountered this concern? Appreciate any hint on this. Thank you very much.
Ke_Xu
by Esri Contributor
Hi @jantolihao
Currently, it is not possible to modify the color of the flash. I recommend submitting this issue to the ArcGIS Experience Builder Idea board. https://community.esri.com/t5/arcgis-experience-builder-ideas/idb-p/arcgis-experience-builder-ideas
Ke
Ke_Xu
by Esri Contributor
Hi @jantolihao
Ke
