I have an ExB app built that shows a subset of Indoors Units in a List widget. There is also a map widget that is configured as floor aware. Ideally the workflow is to select an item in the list and have the map zoom to and filter the proper floor in order to display that unit on the map. I don't seem to see a way to be able to select an item from the List and have an action that changes the floor filter widget to the proper floor.
Does this functionality exist? If not, does anyone have a workaround?
