I have an idea about using selected features in an analysis tool in Experience Builder
If I use the select tool to select let's say 10 houses from a building layer, I want to be able to take that building layer and use as an input to for instance the buffer tool..
But at the moment it doesn't honor the selection.. it just takes all the features in the layer..
So it would be great if the selected features in the layer would be possible to use as the input.
This should of course also be possible with a GP/Web tool that you publish your self.
Our organization is currently using this functionality in WAB with multiple custom GP tools. It is critical to our work-flows and processes. We really need this available in the Experience Builder Analysis Widget if we are expected to migrate our apps from WAB!
