I'd like the Near me widget to have the same functionality of the old screening widget in the web app builder, so that users can select features in an existing layer on the map. I know this functunality is available by selecting the features first, opening up the table for this layer, and then actions > set location, but that seems like a very lengthy process to follow, and something that would not be easily understood/known unless you are shown. It also seems a rather lengthy process. The screening widget previously had all of this functunality in the one window, so it was easier for the user to understand and use.
You also used to be able to export the results in one excel spreadsheet but it now seems each analysis layer needs to be export individually, it would be great if these could be combined into one export
