ArcGIS Experience Builder functionality that allows users to filter a layer by two or more attributes simultaneously.
For example, a widget which can filter a dataset on attribute 1 and attribute 2 at the same time. Both filters would need to be controlled independently of each other.
The current Filter Widget allows for the creation of an arbitrary number of filters that can all be toggled independently and work at the same time. Here is an example of a project that uses about 30 filter options.
