What is the Largest Tile Cache You've Created?
2076
6
03-18-2016 06:37 AM
DaveTenney
All,
    so I was thinking...
i have published a map service with ortho imagery for one of the smallest states by area in the US and it takes 10 days to create the cache.
i was wondering if anyone has published service with a much larger state by area? the thought of it taking over a month to create a cache keeps me up at night.
thanks
dave
DanDowning
We've done the state of Florida. We had many issues. Time to cache and size of cache definitely contributed, but publishing from a windows environment to linux ArcGIS Server was also a major obstacle. There was a whole process we had to do creating a mosaic dataset and then breaking the file paths and then copying to the linux box because of the file path differences between windows and linux. It's been awhile so I don't remember the exact details, but I believe the time was 9 - 12 days and close to a terabyte of disk space. We had four server boxes assigned to tile creation.
RebeccaStrauch__GISP
I've cache the state of Alaska  at 10 LOD and it took about 8 weeks (v10.2.x).  Since then we purchased the Image Server extension, added 4 additional level of detail and (if not for other network issues) it would only take and estimate of about 2 weeks.  Being able to use the mosaic datasets greatly improved the speed.  But the Image Server extension also eliminates the need for some of the caches since it does faster on-the-fly display.
ModyBuchbinder
Hi
I would be very interest in this information.
I think the important parameter is the area and the smallest scale.
We created cache down to 1:1000 for about 20000 square kilometer.
I think it took less than a week using 6 processes.
The interest point is when you start the process each of these 6 processes is using a full core (12% in case of 8 core machine) but after a few hours is slowly going down to 2-3% per process.
We use the image extension.
GISSupport3
Did you modify the number of instances of CachingControllers and CachingTools Services?
ModyBuchbinder
I used 6 instences on 8 core machine
DaveTenney
i guess while were on the topic of # of cores....
   for a statewide deployment where you have a desktop application calling on services in almost 300 locations with a total of 800 seats statewide...
     2 VMs
     4 Cores each
     2 instances each
I guess i would be interested in knowing if other would find that sufficient of it should be bumped to say something like 8 cores per VM and something like 4-6 instances?
thanks for everyones comments, this have been a great thread so far!
dave
