Return list of users locking/using an object
300
05-08-2023 03:24 PM
JoseG_Esri
New Contributor II
Is there a way to return the list of users locking a distinct geodatabase object (feature class, object table, domain) using python/arcpy ?  if there is no way now, can this be added as a new feature..?
Kara_Shindle
Occasional Contributor III
I once saw a blog post example for returning a list of connected users in order to send them an email before database reconciliation occurred.  Seems like that would be a good starting point.
That particular example in my code looks like the following:
sdeConnection = r"Insert/your/path/here"
#list users connected to database
userList = arcpy.ListUsers(sdeConnection)
# get a list of user names from the list of named tuples returned from ListUsers
userNames = [u.Name for u in userList]
mylist = list(dict.fromkeys(userNames))
#I removed a few extra characters to clean up the user list because I needed to create emails, so you'll have to work on this part to customize it to your needs
mylist.remove('DBO')
mylist = [(name[10:-1]) for name in mylist ]
Edit:
Here is the link to the syntax doc.
Here is a GeoNet post where someone is working through the example I mentioned, & they link back to the original post.
