Custom print service stops working after ArcGIS Server upgrade to 10.9
1099
5
09-30-2021 11:14 AM
Col_Forbin
I had a custom print service running in standalone ArcGIS Server 10.8.1.  The service was published from ArcGIS Pro, and used built-in credentials to allow printing secured feature services.  After upgrading the server to 10.9, this service stopped working.  Server logs show:
Failed to create layer from service at: [REST Endpoint of map service]
The built-in credentials have privileges on the secure services.  Printing web maps with public services works as expected.
I have installed all patches for 10.9.
I have a support ticket in with tech support and no solution yet, but I am wondering if anyone else has experienced this issue with custom print services and secured map services with AGS 10.9?
IhabHassan
for some reason, this issue kinda ringing a bell.
Did you try to republish the service using your built-in credentials?
Regards
Ihab
Col_Forbin
Hi Ihab,
Thanks for the reply.  Yes I did republish the service with the credentials and the problem persists.  Tech support has advised they believe it may be a problem with the 10.9 update, but it is not confirmed yet.
Col_Forbin
Further response from support indicates the workaround is to publish the custom print service from ArcMap, which I have tested and it does solve the problem for now while Esri investigates the issue further.
dd_dev
Do you know if this issue was ever resolved?
dd_dev
To update.. strangely enough, they just released a patch yesterday (like 3-4 hrs after I asked this question) that resolved the issue for us!!
