ArcGIS Enterprise Log4j Vulnerability (CVE-2021-44228) Patch or Mitigation?
48932
162
12-11-2021 09:13 AM
Carl_Flint
Good afternoon, is there any patches in the works or potential mitigation steps for the latest java log4j vulnerability (CVE-2021-44228)?  I know that GeoEvent server uses log4j and can assume some other enterprise server's or portal potentially do as well.  Any help would be appreciated in resolving this zero-day.
Carl Flint, GISP
Kai_Ole_Rogge_Allianz
ArcGIS Enterprise base deployment shows more then 50 affected .jar files (Esri and 3rd party like Elasticsearch).
Looking forward to any updates/patches/support.
Cheers
Kai
MarkusRuottinen
Hi
Do you know is it possible to set environment variables which ArcGIS Server uses in windows server.?
I ask this because https://logging.apache.org/log4j/2.x/security.html says: "Mitigation: In releases >=2.10, this behavior can be mitigated by setting either the system property log4j2.formatMsgNoLookups or the environment variable LOG4J_FORMAT_MSG_NO_LOOKUPS to true. "
I just ask, I don't know is this correct solution.
Br
Markus
Swani_Jesus_Captonsiluvairajan
Do we have any updates on this?   Do we have to shutdown the portal and server services as a precaution?
RandallWilliams
Our current statement is available on https://trust.arcgis.com. Look for more updates as this issue evolves.
GianniCampanile2
Hi Randall,
the statement does not make clear a couple of important points:
- does 10.9.1 version definitevely solves the problem ?
- is the problem only for ArcGIS Enterprise JAVA version or also for .Net one ?
Gianni
AdrianMarsden
Regular Contributor II
the blog says "mitigated" with 10.9 - "to make (something) less severe, harmful, or painful. "
GianniCampanile2
Hi Adrian,
the mitigation statement is for 10.8.1 version, while regarding 10.9 it says "We recommend updating to the latest version of 10.9.1 for the strongest security posture" and I can't figure out if it's a solution or just a generic recommendation.
Gianni
AdrianMarsden
I read it differently
  1. Upgrade to ArcGIS Enterprise 10.8 or later, as risk is mitigated with these versions – We recommend updating to the latest version of 10.9.1 for the strongest security posture.
so version 10.8 and above "mitigate" and of course 10,9 will always be best
MichaelRobb
10.9 is not ideal as 10.9 is a 'short release'.   it would have to be 10.9.1
SreehariGomasani
How do I check the Log4j Vulnerability to my current system? As I am currently using  ESRI Enterprise 10.4
