Environment: ArcGIS Enterprise 11.1 (GIS/Hosting/GeoEvent all federated with Portal) on Windows
Just wanted to report a possible bug:
While troubleshooting another problem, I stumbled across this neat little tool called "operationalhealth.py" in <Portal Install>\tools\operationalhealth. But it appears to be confused if the environment includes other federated servers/components.
Specifically: ArcGIS Enterprise 11.1 running with a federated GeoEvent server -- operationalhealth.py seems to believe we have a managed relational datastore and tile cache registered on the geoevent server. At the moment, there are no datastores registered with the geoevent server.
The error messages are,
2023-10-24 05:25:07,922 [INFO] OH31: All data stores registered to https://geoevent-server/geoevent are validating.
2023-10-24 05:25:08,308 [ERROR] OH36: The relational ArcGIS Data Store component is registered with the site at https://geoevent-server/geoevent, which is not the hosting site for the organization.
2023-10-24 05:25:08,368 [ERROR] OH36: The tileCache ArcGIS Data Store component is registered with the site at https://geoevent-server/geoevent, which is not the hosting site for the organization.
2023-10-24 05:25:08,426 [CRITICAL] Traceback (most recent call last):
File "C:\Program Files\ArcGIS\Portal\tools\operationalhealth\operationalhealth.py", line 1388, in <module>
opHealth.checkNonHostingArcGISDataStore()
File "C:\Program Files\ArcGIS\Portal\tools\operationalhealth\operationalhealth.py", line 657, in checkNonHostingArcGISDataStore
if not server['isHosted'] and 'AGSDataStore' in item['path']:
TypeError: 'NoneType' object is not subscriptable
Hope this helps!
Derek
P.S. Thanks to the individual/s who created (and shipped) this tool!
Hello @dky ,
I agree that this script is very useful. I think that this is a BUG as well. I tried the same with my environment which as follows
In my case it seems to think the following:
As shown below:
However, I noticed something that we both have common error "[ERROR] OH36" which seems to be the cause of the problem. As per the documentation (shared below) "[ERROR] OH36" should not even be checked, the checks are only till "OH35" which seems to be the problem altogether
I will run some more tests and will share the details with you soon.
Hope it helps!
-Archit
This will be fixed in the upcoming 11.2 release. Here's the defect for reference:
BUG-000158207 Operational health script throws exception if machines do not exist for ArcGIS Data Stores like graph and object stores on non-hosting site
@ChristopherPawlyszyn We hit the same issue with 11.1, is there a new version we can get for 11.1 or can we pull it from an 11.2 install?
Hello everyone,
I have encountered the same issue in the last release 11.2 in two environments (Staging, and Production). I would appreciate if anyone from Esri team could tell if they reported this in the last release.
Hello @mabdraboh,
I tested this on 11.2 several types of environment listed below and the results :
And I can confirm that the tool works in certain scenarios for 11.2 environment but still completes the run. Hence, I would request if you can share more details about the error perhaps we can try to check what is happening.
I tested what you mentioned as well. I coped the "operationalhealth" folder from 11.2 to 11.1 environment and it gives the same error mentioned above "[ERROR] OH36" as mentioned before.
Hope it helps!
-Archit
