ArcGIS Data Store upgrade 10.7.1 to 11.3 failed to upgrade PostgreSQL relational data store
1202
10
09-05-2024 11:43 AM
JamesBrattonVHB
I upgraded ArcGIS Enterprise from 10.7.1 to 11.3.  Every upgrade (Portal, Server, web adaptors, Data Store) reported success on the upgrade.  When I validate the relational data store, it fails with the error message:
When I run describedatastore, it says the data store is 11.3.0.51575.
Checking the log files, I see
If I connect to the relational data store, it says that the database is version 10.7.1.  I tried to connect with ArcGIS Pro, but it fails to connect with error: Database Connection: FDO error: -2147216086.  So it appears that the Data Store upgraded to 11.3, but the underlying relational data store is still at 10.7.1.  How can I get that database upgraded or get it to validate properly?
JamesBrattonVHB
Esri says that it has worked for some customers to execute C:\Program Files\ArcGIS\DataStore\bin\gdbupgrade.exe.  This did not work in my situation.
CodyPatterson
Hey @JamesBrattonVHB
Due to the complexities of the Datastore, I try to refrain from putting out guesses and suggestions that may cause data loss, the most I'd recommend to try is a restart, but I'm sure that it won't fix it. My current suggestion would be to reach out to ESRI support, this is definitely something an expert should check out.
Cody
JamesBrattonVHB
Thanks.  I have tried a repair, service restart, and server reboot.  The data store is still not validating.  I've opened a ticket with Esri too.
David_McRitchie
Hey James as Cody mentioned for certainity it is good to keep several backups, ideally a content backup and cold machine backup.
If possible I would try restoring back to 10.7.1 and then testing an upgrade to 10.9.1. There are a lot of functional changes and this is the generally recommended update pattern.
Hope that helps,
David
Esri UK -Technical Support Analyst
JamesBrattonVHB
I heard back from Esri today.  This is a bug that is fixed in 11.4.  I understand that I could go through 2 upgrades to get to 11.3, but I was wondering if anyone knew a way to upgrade the database directly.  I suspect that users may have made changes after the 11.3 upgrade, and I want to avoid losing data.  BUG-000169801 for ArcGIS Data Store (esri.com)
JustinS
@JamesBrattonVHB, generally speaking, it's atypical to upgrade ArcGIS Datastore outside of our publicly documented workflow(s). I think it's probably best to continue working with Support.
JamesBrattonVHB
JamesMarok1
So what was your actual solution in the end? I am having this same problem. Wish ESRI would upgrade their guides to warn people.
JamesBrattonVHB
I was not able to upgrade the database, so I had to restore the 10.7.1 backup and upgrade to 10.9.1.  You don't have to go to 10.9.1, but you can't go directly to 11.3.
JamesMarok1
I was afraid of that ESRI told me to go back to 10.7 then do 10.9 then 10.9.1 then 11.1 and then 11.4 *cries*
