Greetings
I want to publish a map that contains layers
But these Layers have permissions for some users
What is the best way to publish the map and layers?
With the possibility of specifying the permissions for each of them separately
So that I can effectively control user permissions on each layer
Thank you
You should check this: https://enterprise.arcgis.com/en/portal/latest/use/best-practices-share.htm
Thank you
I have read the instructions in the link
But the idea did not come to me
I hope you will excuse me for repeating the question, and I will shorten the question
The question is: I want the ability to permissions for users on each layer in the map?
Thank you very much
