Can someone advise I want to create a dashboard using future layers from the Survey123 URL but getting the message that the layers are not accessible. What to do?
Can you try:
The layer not accessible message is generally something you might see on Feature Collection:
I wonder if you are using one of the default survey layers where querying is disabled. Using the steps above will give access and secure your data.
@DrJumaKhudonazarov
Is the survey published yet? Are you using AGOL or enterprise? Did you create the survey on survey123 online or connect?
Thanks. Yes published, used connect , using AGC GIS online organisation
i am getting above message
Can you try:
Thanks this was very useful advice and great support
