can i switch the map in a dashboard map widget?
1866
06-05-2019 09:37 AM
LynnBerni
Occasional Contributor II
I have a dashboard set up with a map widget, with all the associated filters etc. already configured. Now I want to use a different map, but cannot figure out how to make this change.
Is this possible? Or will I need to add a new map and redo all the configuration settings?
MichaelVolz
Esteemed Contributor
The administration of a widget such as this in a web app should allow a map to be changed if it has the same configured layers in it.  If this is not that case, this will lead to a considerable amount of rework (maintenance) to be done which management is never happy about.  This type of rework can occur if the web map json is out-of-sync with web app after web map changes and one UNSUPPORTED ESRI solution is AGOL Assistant.
LynnBerni
It is essentially the same map, with all the same layers (plus a few others), but you make an excellent point how that could easily break all the app "components" on the dashboard.  In my particular case I don't think it would have.
DerekLaw
Esri Esteemed Contributor
Hi Lynn,
> I have a dashboard set up with a map widget, with all the associated filters etc. already configured. Now I want to use a different map, but cannot figure out how to make this change. ... Is this possible?
This is not a supported workflow. Please vote for the enhancement,
https://community.esri.com/ideas/14350
Hope this helps,
BillFox
MVP Frequent Contributor
along the same line, please vote for this one too
https://community.esri.com/ideas/15372
