I'm working with ArcGIS Portal and attempting to set up relationship tables to create subforms in Collector as per this article...Related Tables – Exploring New Ways to use Collector for ArcGIS | ArcGIS Blog
I've managed to get everything loaded and even added one entry to the sub table. When I try and add a second I get this error message when trying to finalise the input "The operation couldn't be completed. Database error has occurred.". My relationship class includes one to many so I'm confused why this doesn't work.
Am I missing something, or a setting?
Or, is this because Portal, rather than ArcGIS Online, doesn't fully support this feature. If so when will it be available as it would be incredibly useful
Hi David-
Have you had any success in resolving this issue? If you are still having problems, please post an update to let us know, we can discuss some troubleshooting ideas.
There is no restriction with Portal for ArcGIS.
-Doug
Hi Doug
I was able to get it to work on a simplified version of the data collection. I think linking the relationship table via ObjectID was probably a mistake. When linking it to something else it worked of in the simple version. I'll try adding in domains again and see if it works still
Hi David-
Yes, if you are looking for a unique primary key for your relationship I'd suggest adding and using a GlobalID field to your featureclass as opposed to the ObjectID.
-Doug
Hi Doug
This now works but I'm having an issue downloading for offline collection in the Collector App. I get an error saying it cannot replicate. Any ideas?
I have tested by adding to a map that definitely worked for download previously but get the same issue
Any ideas?
