@egibson0205 If your goal is to summarize the variables from your point locations using boundaries, I recommend you try Suitability Analysis.
1. Create your custom data using your point data. You can setup your variables as Sum or Average:
2. Define your geography boundaries. For example, I'm using zip codes that overlap my point data and I want to summarize the points in each zipcode.
3. I'll go to Run Analysis > Suitability Analysis and add the variables I setup in custom data.
4. You can see the attributes from your point custom data will be summarized (Sum or Average).
5. The other option is to run Comparison reports. You can select your zipcodes as sites and then add your point custom data variables.
I hope this helps!
Fasil
