Thank you for providing these details. After installing Player 5.2 on my device and running Map Tour (5.3) with your Map Tour ID's, I'm unable to reproduce this crash. I'd recommend trying a few things.
First, update your player apps to the latest version, 5.3, and run your app.
Second, try cloud making your app and installing the app to your device and see if this native app is also crashing.
Thirdly (based on assumption you have customized the Map Tour app with code), try creating a fresh Map Tour (5.3) app and run this app with the default tours included. See if this causes the crash. If not, add your custom tours and run this to see if this is causing the crash. If no crashes occur, then dive into any code changes you made that could be causing this.
For the console to work, both the pc running the console tool and the mobile device connecting have to be on the same network. Make sure they are. If they are, the console.log() should print out just as they would if the app is ran through Qt Creator.
