AppStudio 2.1 has introduced Secure Storage plugin (BETA) that provides a way to store and access sensitive information such as credentials, tokens etc. With Secure Storage, your data is now encrypted and store in the system provided keychain and can only be accessed by the app. Let’s dive deeper to find out what is Secure Storage and how to use it.
Note: This functionality is currently in BETA, which essentially means go ahead and use it but there might be slight modifications/enhancements made in the future releases based on usage and feedback. This also means that we are looking forward to your feedback.
Overview
SecureStorage singleton is part of the SecureStorage module, it allows you to store and retrieve data directly with ease in a cross-platform way. In its first implementation, you can store as key value pairs and retrieve data as a string format and each value is limited to 240 characters (technical limitation to provide cross-platform support). However, there is no limit on how many key/value pairs you can create.
On a side note, when testing your app that uses SecureStorage inside of player make sure there are no collisions with key names since inside player both your app and the player app will be using the same keychains. You can easily make your key unique by adding a prefix such as your app name.
Supported Platforms
- Android
- iOS
- Mac OS
- Linux
- Windows
SecureStorage provides two methods and a signal (event):
Method:
- Bool setValue (String key, String value) – Returns a boolean value indicating the data was stored encrypted in the system keychain. This method is also used to remove the existing keys from the keychain by providing a valid key name and empty string for the value.
- If you use the same key twice the previous one will be overwritten
- Keys cannot be null or empty
- If you enter a valid key with empty string, it will remove the key present in the keychain
- String value(String key) – Returns string value which is the data associated with the key
Signal:
- error(String errorMessage) - Emits when there is an unacceptable behavior when you try the above methods
How to use Secure Storage plugin
This step - by - step tutorial will walk you through how to use Secure Storage plugin in your AppStudio apps.
Step 1
Import Secure Storage plugin statement
import ArcGIS.AppFramework.SecureStorage 1.0
Step 2
Store data into system Keychain
TextField {
placeholderText: "Enter key"
TextField {
placeholderText: "Enter value"
anchors.left: key.right
//Click on the button to store data into the keychain
Button {
text: qsTr("Secure Data")
anchors.top: key.bottom
onClicked: {
SecureStorage.setValue(key.text,value.text)
Step 3
Add a Retrieve button, click on the button to retrieve data from Keychain.
//Click on the button to retrieve data
Button {
text: qsTr("Retrieve Data")
anchors.top:secureButton.bottom
onClicked: {
retrieveData.text = qsTr("Value: ") + SecureStorage.value(key.text)
//Display retrieved data
Text{
anchors.top: retrieveButton.bottom
Step 4
Display the error message while failing to store and retrieve data
Text {
anchors.top: retrieveData.bottom
Connections{
target: SecureStorage
onError: {
errorData.text = errorMessage;
Secure Storage Sample
We have provided a sample to help you learn how to use Secure Storage plugin. It is available in AppStudio Desktop 2.1 via "New App" dialog:
- Open AppStudio Desktop
- Click on the New App button
- Search and select Secure Storage sample
- Click on the Create Button
This sample is also available in the appstudio-samples GitHub repo
If you have any feedback or suggestions, let us know in the comments!
To learn more about Secure Storage, check out the API reference.
