Using either the ArcGIS API for Python arcis api for python or the AGOL Web UI, I am not able delete coded domain values (CDV) that were mistakenly added to a field. The field has a sub-type associated with it, but even in an earlier test version, without the subtype, if I use the update_definition or delete_from_definition methods the CDVs seem to "stick"
Anyone have an example - ideally scripted - on how I am supposed to remove - I was able to add CDVs through the python API, so I assume I should be able to remove them, yes?
