Local Government Information Model
5212
03-22-2016 08:14 AM
PrestonStafford
Can someone tell me how to find the Local Government Information Model? I have look through ArcGIS Online cannot find it.
SamuelTompsett
Occasional Contributor II
Hi Preston,
You can navigate to the solutions page below:
Local Government Information Model | ArcGIS for Local Government
Hit the download button and you should get:
DataDictionary.htmThe data dictionary for the Local Government Information Model that includes a description of the features, fields and domains in the information model.
LocalGovernment.xmlThe XML workspace document used to deliver an empty schema of the Local Government Information Model.
LocalGovernmentReleaseNotes.pdfThe release notes that describe changes made to each incremental version of the Local Government Information Model.
The XML document included in the download can be imported to a file geodatabase or enterprise geodatabase by using the Import XML Workspace Document tool.
Import XML Workspace Document—Help | ArcGIS for Desktop
Hopefully that helps!
-Sam
Karen
I am following the directions to import the LocalGovernment.xml but I am unable to find where you download the XML file from.  This is at the step where you import the Local Government schema?
TiffanyPuett
Karen,
Good luck finding it. It has been placed on mature support. Perhaps Esri support can guide you to the location? If there is a specific solution you are attempting to create/configure you can try the new solutions app: https://www.esri.com/en-us/arcgis/products/arcgis-solutions/overview
