Hi there,
I'm pretty sure you will need to define the projection with a vertical coordinate system, even if it has a z value in the geometry. If you don't already know, there is a geoprocessing tool called Define Projection that will define the vertical coordinate system. It looks like you are working in state plane, so I believe you would select NAVD88_height. This is a late response but I hope this helps!
