Roberts Custom WAB Widgets
406815
475
12-31-2014 11:28 AM
AnthonyKeogh1
Hi Robert, thanks for replying, that's useful to know.
deleted-user-FfGbgR253rTy
Hey, if you're looking for ideas, I'd love to be able to do an advanced search and/or edit features based on coordinates I type in, rather than the existing options...
GabiVoicu
Could eSearch have mailing labels added - please - to be considered as Parcel Notification widget?
Thank you
RobertScheitlin__GISP
Gabi,
  The PublicNotification template uses custom print templates to achieve mailing label and I do not intend to host custom print services and templates that eSearch users will use to achieve mailing label functionality. So no, this will not be added to the eSearch.
ThomasWeitzel
Hi Robert,
Are you releasing these widgets under any particular open source license - Apache, MIT, LGPL, etc.?  If not, what are the terms for use?
Tom
Tom,
   They all are under the Apache license. I have found that I failed to include that in the source code for many of them but I go on record now stating that they are released under the Apache license.
ThomasWeitzel
Good to know.  Thanks!
ReginaldoPaderon
Hi rscheitlin ( again ) ,
Sorry Robert, I am a fan and regular user of all your widgets ( FV and WAB ).  I just started with WAB and I slowly migrating my Flex apps to WAB.  That means , your FV widgets to WAB too 🙂
Just one issue I am having with eSearch.  When I am using "IN" operator in my expression with Integers I am getting "The value entered is not valid"  but not so with Strings.  I simulated the same with your Flexviewer eSearch and it is working fine.
I am using WAB for ArcGIS Dev Ed 2.1 and eSearch downloaded from this thread.
Eggie
Eggie,
  Looking at my code I can not see why this would be happening. I have code in place to test if the expression is a string then it ill wrap all values with a single quote:
/*If the expression is an IN Statement and the the value is a string then
replace the user defines comma seperated values with single quoted values*/
if (queryExpr.toLowerCase().indexOf(" in (") > 0 && queryExpr.toLowerCase().indexOf("'[value]'") > -1) {
//replace the begining and trailing single qoutes if they exist
eVal = eVal.replace(/^'|'$/g, "").replace(/,|','/g, "','");
So the check is if the layers expression has '[value]' then it is a string expression.
i.e. the config_Enhanced Search.json has
"sqltext": "DOCNAME = '[value]'",
"operation": "stringOperatorIs",
ReginaldoPaderon
Hi Robert,
Thanks for your reply.
Sorry, I may not have made my query clear.
My issue is with an Integer data type.  No issues with Strings. Strings are working fine.
From the widget:
SQL Statement:
REFNO IN ([value])
Thanks Robert ...
