Show orthomosaics from different flights in the same dashboard
1016
5
08-16-2022 03:09 AM
ManuelCarpintero
Hello
Does anybody know how to show in the same Site Scan dashboard orthomosaics from different flights of a project? . I mean, it could be inside of a mission. I have an orthomosaic (1) and I would like to show the surrounding missions ortho on the same dashboard  (2-3-4).
3 Solutions
Andrew-Bowne
Merging missions might be your best bet.  You can process the merge at the same time you are processing each individual mission.  That might help speed up the process.
NicoBonnafoux
Hi @ManuelCarpintero
  • If the images were captured the same day, merging the missions into one and processing them together is your best option as @Andrew-Bowne suggested.
  • If the missions are from different days, you can:
    • Use the "See All Missions" view:
      • From the mission 2D view, click the mission data and name,
      • At the bottom of the list, click "See All Missions"
      • Select the desired missions to display from the list on the left or by selecting their footprint on the max view. (Footprints can be hidden using the button in the upper-right of the screen)
      • If you're trying to share this, publishing your orthos as tile layers to ArcGIS Online or ArcGIS Enterprise, creating a web-map, and sharing it is likely your best option. This will give you the ability to add other content and update it in the future.
ManuelCarpintero
Hi Nico,
That's, what I was looking for. I knew it exist because I attended some webinars but I did not remember where to find it.
Thank you,
Andrew-Bowne
You could merge all of the missions together into one mission.  You could also download each of the processed tiff's and mosaic them.  or... you could share each of them out to ArcGIS online or your own Portal and create your own dashboard.
ManuelCarpintero
Hi Andrew,
Thanks for your answer. This, I already have considered, but that I would like to have is the possibility to see and share faster the orthomosaic. When I share with third parties without no knowledge they just want to have all ortho together.
Andrew-Bowne
NicoBonnafoux
ManuelCarpintero
Hi Nico,
Thank you,
