Why does code collapse in threads?
2053
07-02-2021 09:07 PM
LanceKirby2
The title says it all. Why does code collapse from a vertical formatted structure to a horizontal unformatted structure when people reply with code? Is there anyway to view the original formatted code?
DanPatterson
MVP Esteemed Contributor
two reasons
first, people weren't using Code formatting ... the Community Version - Esri Community
to format their code
second, threads that pre-date the transition from "GeoNet" to "esri Community" were often collapsed because the pre-existing code formatting structure didn't carry forward, leaving most/many posts with their code flattened.    Check the date of the pre-existing code, if it was before Nov 2020 it in all likelihood has flattened code.  You can copy and recover the code, but you will have to recreate the indentation levels while parsing into lines of code.
For example, from  Transect lines, parallel lines, offset lines - Esri Community
rads = np.deg2rad(bearing)    dx = np.sin(rads) * dist    dy = np.cos(rads) * dist    #    n = len(bearing)    N = [N, n][n>1]  # either the number of lines or bearings‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
has to be reformatted to read
n = len(bearing)
N = [N, n][n>1]  # either the number of lines or bearings;
... sort of retired...
DanPatterson
two reasons
n = len(bearing)
LanceKirby2
Thanks @DanPatterson. You are always very helpful.
That explains it all. Very unfortunate that happened in the transition as some code isn’t as simple to reformat as your example above.
DanPatterson
Tell me about it... I have over 100 blog posts that got de-formatted 😉
