How to control display order of arcpy scripted coded value domain?
6492
12
07-12-2017 10:33 AM
ChristopherRoss1
I use a python script to create and populate coded text domain values for an SDE. The script adds the coded values in the order that I want them (using AddCodedValueToDomain_management), which is in order of usefulness, not alphabetical. My problem is that when I review the text domains in Catalog, they are in a scrambled order. Is there a way to control or change this order?
I am aware of the SortCodedValueDomain_management, but that seems to only allow ascending and descending sorting.
RandyBurton
Typically, when I create domains, I create a table, add the fields and then import data from a spreadsheet.  Then I convert the table to a domain.  The process is automated with a python script. See my comments in Importing domains from Excel for a sample script.
RebeccaStrauch__GISP
I second Rhett Zufelt  and rvburton  about keeping it in a table (mine are in FGDB tables) and then replacing the domains with TableToDomains.  It is easier to sort the table and it seems to always keep the order I set.  I have script setup that replaces about 70 different domains (and sets subtypes) every month or as needed to both my master SDE and FGDB copies of my FCs,
ChristopherRoss1
This is a good option to retain the coded text in its original design, great solution.
