Custom tool error
3718
05-23-2016 04:34 AM
SadanandacharB1
Hi All
      As suggestions given in the blog i modified the script, But still i am getting the same error please help me
when i run the script in python editor with workspaces hardcoded like below, the code executes properly.
import arcpy
... import os
... from arcpy import env
... env.overwriteOutput = True
... env.workspace = "D:/Python DVD/Python/Data/Exercise02"
... outgdb = "D:/Data/Test1.gdb"
... print outgdb
... fclist = arcpy.ListFeatureClasses()
... for fc in fclist:
...     fcdesc = arcpy.Describe(fc)
        print fcdesc.baseName
        print  os.path.join(outgdb, fcdesc.baseName)
...     arcpy.CopyFeatures_management(fc, os.path.join(outgdb, fcdesc.baseName))
But when i create custom tool using this script i am getting the error
import arcpy
import os
env.workspace = arcpy.GetParameterAsText(0)
outgdb = arcpy.GetParameterAsText(1)
print outgdb
for fc in fclist:
Error is:
FC_Basson
MVP Alum
Ensure that your Geoprocessing environment is configured to allow output overwrite
Overwrite Outputs
SadanandacharB1
Thank you very very much
DanPatterson_Retired
This thread is in essence a duplicate of this thread Error when running custom script tool
and overwriteoutputs was suggested as well.
Respond to the suggestions in one thread as to whether they worked or not before starting a duplicate.
Could you provide more print statements in your code so people can accurately assess what your inputs and outputs are.
