Rolling Statistics for grid data... an alternative
2110
11-14-2017 05:30 PM
DanPatterson_Retired
2 2 2,110
Rolling stats...  The 3x3 moving/sliding/rolling window.. This kernel type will focus on returning statistics like your FocalStatistics functions... but without needing the Spatial Analyst extension...
They are used ....
And there are other uses....
First the results.
a      # ---- A grid/raster/array ----
array([[5, 1, 2, 0, 5, 4, 7, 3, 2, 2],
       [2, 5, 9, 9, 6, 9, 2, 1, 3, 0],
       [7, 2, 7, 4, 4, 4, 3, 7, 7, 7],
       [3, 9, 6, 8, 0, 1, 8, 5, 0, 7],
       [8, 4, 6, 8, 1, 9, 6, 9, 5, 5],
       [3, 9, 9, 5, 3, 1, 5, 5, 2, 3],
       [0, 5, 2, 0, 9, 4, 7, 9, 9, 0],
       [2, 5, 5, 4, 3, 7, 7, 8, 3, 5],
       [5, 2, 4, 5, 3, 6, 5, 2, 7, 2],
       [4, 6, 4, 9, 8, 6, 8, 6, 2, 0]])
a_s = stride(a, r_c=(3,3))  # ---- create an array of rolling windows 3x3 ----
# ---- Now calculate all the statistics --------------------------------------
rolling_stats(a_s, no_null=False, prn=True)
Min...
[[1 0 0 0 2 1 1 0]
 [2 2 0 0 0 1 0 0]
 [2 2 0 0 0 1 0 0]
 [3 4 0 0 0 1 0 0]
 [0 0 0 0 1 1 2 0]
 [0 0 0 0 1 1 2 0]
 [0 0 0 0 3 2 2 0]
 [2 2 3 3 3 2 2 0]]
Max...
[[9 9 9 9 9 9 7 7]
 [9 9 9 9 9 9 8 7]
 [9 9 8 9 9 9 9 9]
 [9 9 9 9 9 9 9 9]
 [9 9 9 9 9 9 9 9]
 [9 9 9 9 9 9 9 9]
 [5 5 9 9 9 9 9 9]
 [6 9 9 9 8 8 8 8]]
Mean...
[[ 4.44  4.33  5.11  5.    4.89  4.44  3.89  3.56]
 [ 5.56  6.56  5.89  5.    4.11  4.44  4.    4.11]
 [ 5.78  6.    4.89  4.33  4.    5.78  5.56  5.78]
 [ 6.33  7.11  5.11  4.    3.78  5.44  5.    4.56]
 [ 5.11  5.33  4.78  4.44  5.    6.11  6.33  5.22]
 [ 4.44  4.89  4.44  4.    5.11  5.89  6.11  4.89]
 [ 3.33  3.56  3.89  4.56  5.67  6.11  6.33  5.  ]
 [ 4.11  4.89  5.    5.67  5.89  6.11  5.33  3.89]]
Med...
[[ 5.  4.  5.  4.  4.  4.  3.  3.]
 [ 6.  7.  6.  4.  4.  4.  3.  5.]
 [ 6.  6.  6.  4.  4.  6.  6.  7.]
 [ 6.  8.  6.  3.  3.  5.  5.  5.]
 [ 5.  5.  5.  4.  5.  6.  6.  5.]
 [ 5.  5.  4.  4.  5.  7.  7.  5.]
 [ 4.  4.  4.  4.  6.  7.  7.  5.]
 [ 4.  5.  4.  6.  6.  6.  6.  3.]]
Sum...
[[40 39 46 45 44 40 35 32]
 [50 59 53 45 37 40 36 37]
 [52 54 44 39 36 52 50 52]
 [57 64 46 36 34 49 45 41]
 [46 48 43 40 45 55 57 47]
 [40 44 40 36 46 53 55 44]
 [30 32 35 41 51 55 57 45]
 [37 44 45 51 53 55 48 35]]
Std...
[[ 2.67  3.2   2.85  2.62  2.02  2.5   2.28  2.59]
 [ 2.59  2.36  2.73  3.09  2.88  2.83  2.71  2.96]
 [ 2.2   2.16  2.73  3.16  2.98  2.62  2.59  2.39]
 [ 2.4   1.79  3.    3.37  3.15  2.83  2.58  2.5 ]
 [ 3.    2.91  3.26  3.34  2.87  2.56  2.26  3.08]
 [ 2.91  2.73  2.83  2.62  2.42  2.28  2.38  3.03]
 [ 1.76  1.71  2.33  2.45  1.94  2.02  2.36  3.2 ]
 [ 1.29  1.79  2.    2.    1.79  1.73  2.31  2.56]]
Var...
[[  7.14  10.22   8.1    6.89   4.1    6.25   5.21   6.69]
 [  6.69   5.58   7.43   9.56   8.32   8.02   7.33   8.77]
 [  4.84   4.67   7.43  10.     8.89   6.84   6.69   5.73]
 [  5.78   3.21   8.99  11.33   9.95   8.02   6.67   6.25]
 [  8.99   8.44  10.62  11.14   8.22   6.54   5.11   9.51]
 [  8.47   7.43   8.02   6.89   5.88   5.21   5.65   9.21]
 [  3.11   2.91   5.43   6.02   3.78   4.1    5.56  10.22]
 [  1.65   3.21   4.     4.     3.21   2.99   5.33   6.54]]
Range
# ---- If you have nodata values, they can be accommodated ------------------‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Now the code functions
import numpy as np
from numpy.lib.stride_tricks import as_strided
def _check(a, r_c, subok=False):
    """Performs the array checks necessary for stride and block.
    : a   - Array or list.
    : r_c - tuple/list/array of rows x cols.
    : subok - from numpy 1.12 added, keep for now
    :Returns:
    :Attempts will be made to ...
    :  produce a shape at least (1*c).  For a scalar, the
    :  minimum shape will be (1*r) for 1D array or (1*c) for 2D
    :  array if r<c.  Be aware
    if isinstance(r_c, (int, float)):
        r_c = (1, int(r_c))
    r, c = r_c
    if a.ndim == 1:
        a = np.atleast_2d(a)
    r, c = r_c = (min(r, a.shape[0]), min(c, a.shape[1]))
    a = np.array(a, copy=False, subok=subok)
    return a, r, c, tuple(r_c)
def _pad(a, nan_edge=False):
    """Pad a sliding array to allow for stats"""
    if nan_edge:
        a = np.pad(a, pad_width=(1, 2), mode="constant",
                   constant_values=(np.NaN, np.NaN))
    else:
        a = np.pad(a, pad_width=(1, 1), mode="reflect")
    return a
def stride(a, r_c=(3, 3)):
    """Provide a 2D sliding/moving view of an array.
    :  There is no edge correction for outputs.
    :Requires:
    : _check(a, r_c) ... Runs the checks on the inputs.
    : a - array or list, usually a 2D array.  Assumes rows is >=1,
    :     it is corrected as is the number of columns.
    : r_c - tuple/list/array of rows x cols.  Attempts  to
    :     minimum shape will be (1*r) for 1D array or 2D
    a, r, c, r_c = _check(a, r_c)
    shape = (a.shape[0] - r + 1, a.shape[1] - c + 1) + r_c
    strides = a.strides * 2
    a_s = (as_strided(a, shape=shape, strides=strides)).squeeze()
    return a_s
# (18) rolling stats .... code section
def rolling_stats(a, no_null=True, prn=True):
    """Statistics on the last two dimensions of an array.
    :Requires
    : a - 2D array  **Note, use 'stride' above to obtain rolling stats
    : no_null - boolean, whether to use masked values (nan) or not.
    : prn - boolean, to print the results or return the values.
    :Returns
    : The results return an array of 4 dimensions representing the original
    : array size and block size
    : eg.  original = 6x6 array   block = 3x3
    :      breaking the array into 4 chunks
    a = np.asarray(a)
    ax = None
    if a.ndim > 1:
        ax = tuple(np.arange(len(a.shape))[-2:])
    if no_null:
        a_min = a.min(axis=ax)
        a_max = a.max(axis=ax)
        a_mean = a.mean(axis=ax)
        a_med = np.median(a, axis=ax)
        a_sum = a.sum(axis=ax)
        a_std = a.std(axis=ax)
        a_var = a.var(axis=ax)
        a_ptp = a_max - a_min
    else:
        a_min = np.nanmin(a, axis=(ax))
        a_max = np.nanmax(a, axis=(ax))
        a_mean = np.nanmean(a, axis=(ax))
        a_med = np.nanmedian(a, axis=(ax))
        a_sum = np.nansum(a, axis=(ax))
        a_std = np.nanstd(a, axis=(ax))
        a_var = np.nanvar(a, axis=(ax))
    if prn:
        s = ['Min', 'Max', 'Mean', 'Med', 'Sum', 'Std', 'Var', 'Range']
        frmt = "...\n{}\n".join([i for i in s])
        v = [a_min, a_max, a_mean, a_med, a_sum, a_std, a_var, a_ptp]
        args = [indent(str(i), '... ') for i in v]
        print(frmt.format(*args))
    else:
        return a_min, a_max, a_mean, a_med, a_sum, a_std, a_var, a_ptp
2 Comments
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
