Dear Community,
I have a question about dynamic text tags in ArcGIS Pro and their use in print layouts in an custom print service in ArcGIS Enterprise.
We are using ArcGIS Pro 3.5.4 and ArcGIS Enterprise 11.5.
Specifically, we are using the dynamic text tags <dyn type="mapframe" name="Map Frame" property="metadata" attribute="summary" />, <dyn type="mapframe" name="Map Frame" property="metadata" attribute="description"/> and <dyn type="layout" name="LayoutName" property="datePrinted" format="short|short" preStr="last printed: " postStr=" Uhr" /> in print layouts in ArcGIS Pro.
Unfortunately, these tags were not dynamically filled via my published custom print Service in Map Viewer or in an ArcGIS experience.
Is there an overview from Esri which dynamic text tags from ArcGIS Pro are supported in a web context (Map Viewer, Experience, etc.)? Unfortunately, I have not been able to find any sources about that in the Internet. I found just some information about some layout Tags, that these get dynamically filled in the Web Context.
Does anyone know if there is a workaround for these named dynamic text tags so that these Information also gets dynamically filled in the web context?
Best regards,
Tim
