publishing Service "Startup time out during the processing data phase"
477
04-12-2019 12:45 AM
ElieRizk
hello,
I am using ArcGIS for server 10.5 and I have MXD with more than 1500 scanned images, the scanned images are stored in a folder on the map server machine where the ArcGIS installed.
the problem is that I am not able to publish this map service with this count of images (startup time error generated) during the publishing. (noting that this map was previously working fine and unfortunately stopped by the ArcGIS server).
I tried to reduce the number to 1250 and successfully published. when trying to increase this number the publishing service startup time out.
