Military Tools data is not editable in the portal
473
03-12-2025 02:09 AM
PaulJohns
Hi everyone,
I have a local ArcGIS Pro project where I’ve collected different symbols created using Military Tools. I’m trying to publish it to a portal. The first step I took was copying the data from a local geodatabase (GDB) to an SDE, applying a web dictionary, and publishing it as a Map Service. Everything works properly. However, when I try to publish the data as a Feature Layer for further editing on the portal, I get an error from the editor widget that says, "You don’t have any permission to edit data." Other data from the SDE database, which wasn’t created using Military Tools, works correctly. Does anyone have any ideas?
Thank you.
Laura
by MVP Regular Contributor
Is your problem when you are publishing or when you are editing in map viewer or an application? Was editing enabled on the layer?
PaulJohns
Hi Laura,
Publishing works fine. However, after activating the Editor Widget, this error appears. Another strange thing is that I can delete a point, but I can’t create a new one or change the geometry position (I mean a published point feature) on the portal, despite this error regarding my administrative permissions.
