Is there a maximum number of layers in MXD to publish to map service?
3999
10-12-2010 09:40 AM
BarbaraPatterson
I have an mxd that contains hundreds of layers that are all OFF and all point to the same feature class. (I have added a layer for each field in the feature class.) I am able to create an msd file and publish the map service but unfortunately the map service fails to start. Since the map service will only ever display one layer at a time, I was hoping that the number of layers would not matter. A couple of questions: is there a maximum number of layers I can have in the mxd? Is there a way to increase the startup timeout interval for starting the map service?
Any suggestions would be appreciated!
Barb Patterson
AlexManduley
Hi Barb,
We're running three services as MSDs with about 600 (and growing) layers apiece. You may just need to set a longer timeout period in order to give it the necessary time to start. Also, I have had significantly better results when the server has two or more cores.
Alex
BarbaraPatterson
Thanks for the feedback - this info will be helpful.
Barb
ElieRizk
hello,
sorry to revive this thread, but I have MXD with more than 1500 scanned images, the scanned images are stored in a folder on the map server machine where the ArcGIS installed.
the problem is that I am not able to publish this map service with this count of images (startup time error generated) during the publishing.
I tried to reduce the number to 1250 and successfully published. when trying to increase this number the publishing service startup time out.
