Basemaps used in geoprocessing services make tool crash
723
06-25-2023 12:40 AM
Roxana_ElenaUrdea
Hi!
I am having problems with geoprocessig services that are using APRX projects with a Basempap layer to produce maps (jpeg). The process gets stuck when retrieving the basemaps from the map object and goes into timeout.
On server side I notices the pop-out that I attach, a security allert that pops out only when I am using the Basemaps. Even if I disable it (also from Inter Explorer) I still have the issue.
This happens on 10.9.1 federated server and 10.5 standalone server.
Is this a new issue?
Thank you,
Roxana
