This may be a dumb question, but I am still confused about it.
At the devsummit we announced that we will be adding support for .NET Core 3.0 to the WPF SDK. Note though that this will be for Windows only, and will not support running it on other platforms .NET Core also runs on.
Timeline depends on when .NET Core 3.0 will finalize, which is currently is scheduled to be "second half of 2019" (see https://devblogs.microsoft.com/dotnet/announcing-net-core-3-preview-3/ )
We'll need a little bit of time after that release to finalize testing and ensure we'll run great on .NET Core 3.0, so we'll support it in the release after that provided we have enough time for doing the testing (otherwise it'll be in a release following that).
Just a follow-up to this: The just-released v100.6 has support for .NET Core 3.0 (as a preview). It will however only run on Windows, and will require the .NET Core 3.0 Desktop packages.
We hope to fully support it by Update 7 on top of .NET Core 3.1, but would love feedback now of anything that might not work as you intended.
I quickly whipped up a sample project for .NET Core 3.0 final to look for performance improvements, and in particular in regards to HTTP/2. However, looking at my IIS server logs, I can see requests made from Chrome are logged with HTTP/2.0, but from the sample application they are logged as 1.1.
It appears that if I handle the ArcGISHttpClientHandler.HttpRequestBegin Event and assign e.Version = new Version(2,0), the requests is actually performed using HTTP/2. Shouldn't the Runtime use HTTP/2 by default without having to opt-in in this way, or is there something that I'm missing?
Looking at a performance, I notice an odd artifact when zooming in and out on the same spot (one delta of the wheel), while there are no requests being made to the server, there is a visual appearance of the tiles being loaded from server rather than quickly/instantly retrieved from the cache, which I find odd. I already have an intermittent dialog with Michael Branscomb on the performance topic, so I was wondering if this should be part of the direct dialog, or in the forums.
We are still evaluating whether to default to HTTP/2 or not. At this point we've decided to use the default version of .NET core and not explicitly set it. See https://github.com/dotnet/corefx/blob/release/3.0/src/System.Net.Http/src/System/Net/Http/HttpUtilities.cs#L17
As mentioned above our .NET Core support isn't fully finalized yet.
Wrt tile performance I'm not entirely following: Are you saying the behavior is different from .NET Framework? We shouldn't be making requests to the server again for the same tiles if the server said that the tiles can be cached.
FYI I've filed a request to update the incorrect .NET Core doc: https://github.com/dotnet/dotnet-api-docs/issues/3319
From my understanding the http/2 implementation in .NET Core isn't fully complete, which is why it isn't default. Once .NET Core considers it feature complete, you should automatically see v2 requests happening. I think that's a better approach than we forcing a version number on the requests (and until then you can use the workaround you found)
Interesting. We are not quite ready to update to .NET Core yet, so we still have some time to work on it, and for MS to do the same. So in the future, the runtime will hopefully use the most suited protocol.
Signed in members can post, follow updates, and more. New here? Register a free account.
