Hi All,
We are using ArcGIS Enterprise 12.0 and encountered an issue using WebGISDR tool when trying to directly upload to Azure Blob Storage
The error message goes like this:
Failed to back up the Relational Data Store
Caused by: Timeout on blocking read 300000000000 NANOSECONDS
For context it took around 5 hours to create the data store back up file and it was around 450GB.
Is there a way to increase the timeout or completely remove it?
Hi @ikelagos,
I would try increasing Portal's token expiration:
Hi there - did you make any progress on this? I'm hitting it as well. In the webgisdr log I see:
"{"jobid":"j65e79912-4aaa-46d3-8b8d-0717760d431b","status":"COMPLETED","stepInfo":["Export operation started.","Export operation failed."],"operationResponse":{"status":"error","messages":["Export operation failed. Failed to write the file '20260505-091124.agssite' to this location 'webgisdr-backup/12-0-0/backup/20260505-091107-backup/server/cd67fdf9jcwpzzk6'"]}}"
while on a manual backup I see:
Failed to write the file '20260505-095011.agssite' to this location 'backup-20260504' Failed to upload backup-20260504/20260505-095011.agssite to object store.. Caused by: Timeout on blocking read for 300000000000 NANOSECONDS
Export operation failed. Failed to write the file '20260505-095011.agssite' to this location 'backup-20260504'
The debug log shows:
Caused by: Timeout on blocking read for 300000000000 NANOSECONDS at com.esri.arcgis.objectstore.clients.azure.AzureBlobStoreClient.putObject(AzureBlobStoreClient.java:986) at com.esri.arcgis.objectstore.clients.azure.AzureBlobStoreClient.putObject(AzureBlobStoreClient.java:915) at com.esri.arcgis.discovery.admin.backuprestore.BackupRestoreUtil.writeSiteFileToBackupStore(BackupRestoreUtil.java:888) at com.esri.arcgis.discovery.admin.SiteManager.exportSite(SiteManager.java:7253)
so I'm not sure if this is a network issue or a client configuration issue.
Are you accessing blob storage over the public internet or via private endpoints? Is your GIS sitting behind an application gateway?
Also note there are 2 bugs currently:
Please let me know if you have found a solution.
Thanks!
