i am working on glacier boundary shape file of Himalaya region, when i applying multiring buffer on it errer is coming always, having errer ID999999?
6927
26
09-17-2015 10:05 PM
LitanMohanty
DanPatterson_Retired
Ahhhh based on your last image, it is clear... it failed because it was being run in 2009
LitanMohanty
Dear sir if the input file format is '' .lyr '', is there any problem sir.
yes...layer files have no table, they  are associated with data, you have to use the shapefile or featureclass
LitanMohanty
sometimes, when i gave layer file as input, it work
LitanMohanty
Dear sir
i couldn't understand ''being run in 2009'', what is mean by 2009.
​look at your results window and the run date  wed may 13 ....2009
some temporal issues with your configuration?
LitanMohanty
Dear sir
i am sharing a link, from which i have downloaded glacier boundary
shape file, you please check what is the problem with this data.
i amworking on Himalaya part only.
http://glims.org/download/
