I am working in 10.4. I have developed a geodatabase with domains and coded values. Is there a way to set up the gdb so that the list of coded values is limited based on the value entered into another attribute field of the same table?
1093
06-20-2018 02:11 PM
ZRex
#coded domains‌geodatabase architecture‌
Asrujit_SenGupta
deleted-user-qpvAI3Fo0MKR
Mr. SenGupta has the correct answer; subtyping out your data and then assigning the appropriate domains is what you're looking for.
ZRex
Thank you very much!
