Older version of the Web App Builder
4047
11-16-2016 07:50 PM
SiaJin_Jun
Is there any way for me to retrieve version 2.0 of the Web App Builder (developer edition)? A project I'm on is using it and there doesn't seem to be any way for us to retrieve older versions of it anymore.
I think the development team may want to consider maintaining the downloads for the older versions as not every project has a development cycle with the bandwidth for web app customizations to be constantly migrated across versions.
DerekLaw
Esri Esteemed Contributor
Hi Sia,
If you need an older release of Web AppBuilder Developer Edition now, please send me an email: dlaw@esri.com and I can send it to you.
FYI, we are in the process of making earlier releases of Web AppBuilder Developer Edition available for download from this page: SDK Downloads | ArcGIS for Developers  by the end of this month.
Hope this helps,
RebeccaStrauch__GISP
did you already delete the .zip file and/or development environment for 2.0?
They took the links to the older versions offline a month or so back....I also do not think this is a good idea.  I can understand not having all versions (they want you to upgrade to keep compatible with other upgrades...i.e. if AGOL effect it), but a few would be nice.
I'll cc dlaw-esristaff
DerekLaw
Hi Sia,
Hope this helps,
DerekLaw
Hi Sia,
FYI, you can now download earlier releases of Web AppBuilder Developer Edition from here,
(look near the bottom of the right column)
Thanks for your patience and hope this helps,
