How to call the Select By Location Tool
2263
09-08-2016 05:10 AM
BradGagliano
Is there a way to call "Select By Location" tool from the Selection Menu, not Select Layer by Location by VB.net and what's the piece of code?
Thanks!!!
NeilAyres
MVP Alum
Well the tool is in the data management toolbox.
select-layer-by-location
NeilAyres
MVP Alum
XanderBakker
Esri Esteemed Contributor
In addition to the link provided by Neil, you should have a look at http://desktop.arcgis.com/en/arcobjects/latest/net/webframe.htm#c4ff8b68-0410-435f-b8e5-682d5cea47cf...  (assuming that you work with ArcObjects), where you can find some sample code and info on how to run a geoprocessing tool from .NET.
